Libreoffice mail merge default file format problems
Picbuster
Joined Dec 2, 2013
1,062
I am using the latest version of linux + latest of libreoffice.
Problem;
merging files working perfect using file as single document output ODF. A bit happy yes but a file name has to typed in every time.
So I tried save as individual document and set generate filename from database.
Not working files are produced but no merge occurred.
Next step changed to .PDF format happy working.
Then I want change the default to .PDF that seems to be not possible or I could not found it at the web (many hours).
It's not in the general setting lost of format but no .PDF
Anyone having the same problems and a solution?
Like to hear from you.
Picbuster
