Jerry-Hat-Trick
- Joined Aug 31, 2022
- 838
With a 4.5V battery the LEDs must be in parallel although it's possible each LED has a resistor in series with it to balance the currents between them.
(1) measure the voltage across the battery
(2) measure the voltage across the resistor - the voltage across the (parallel) LEDs is the difference.
For more information, put a 10 ohm resistor in parallel with the 15 Ohm resistor and measure again and measure the voltage across the battery with no load (if there is no switch, insert a slip of insulating plastic between the cell and the contact with the battery holder) to get an idea of the battery internal resistance. Probably more information than is really needed. The wires going in and out of the LED globes must be insulated.
