LED strip
BobTPH
Joined Jun 5, 2013
11,590
I am giving advice based on the info he gave us. I had previously mentioned that they were likely more like 3.3 to 3.6V, but he insists the are 3V.
27,856
In that table, Balance 5.png, Vf is presented as 3.5 volts. THAT is a number I would expect. 3 volts Vf will be with the LED delivering less light than the specified level. 3.5 volts is a number closer to what I would expect.
Audioguru again
Joined Oct 21, 2019
6,826
The 1/2W resistor will still glow red-hot and maybe will catch on fire because the arithmetic is wrong:
1) 9 LEDs of 3.5V=31.5V.
2) Voltage across each resistor= 48V - 31.5V= 16.5V.
3) 135mA in each string.
4) Resistance of each resistor=16.5V/135mA= 122.2 ohms.
5) Dissipation in each resistor= 16.5V x 135mA= 2.2W.
funguy
Joined Oct 31, 2023
43
Ya I think strings of 6x3.8=22.8
Set buck boost to 24V
24-22.8=1.2
1.2/.135=8 ohms
1.2x8=.162 Watts
72 LEDs/6-12 strings in series placed parallel to each other on the voltage rail
Audioguru again
Joined Oct 21, 2019
6,826
1.2V is OK for a current-limiting resistor of a string of 6 LEDs only if you buy hundreds of LEDs, test them all and pick the few that are at 3.8V.
Did you post the datasheet of your LEDs in this long thread?
Audioguru again
Joined Oct 21, 2019
6,826
Your unknown Taiwan LEDs have 3 forward voltage bins: 1A, 1B and 1C. Which one do you have?
The datasheet does not say the maximum allowed power (voltage x current) at various ambient temperatures for you to calculate a suitable heatsink. Their specs are when the solder pads are at 25 degrees C due to having a "perfect" heatsink.
