LED PWM Frequency design
Ya’akov
Joined Jan 27, 2019
10,292
The PWM control of that IC is not about blink rate. It is used to reduce the current to the LEDs.
Look at the section 3 of the datasheet on the CR Timer:
“Datasheet” said:
This IC determines the flasher cycle from the internal clock generated by CR timer. The CR timer period, ON Duty, can be
set by the external resistor RCRT1, RCRT2 and the capacitance CCRT.
This is where you set the blink rate. You can either ignore the PWM (in which case you get 100% duty cycle) or choose to use it to reduce current to the LEDs.
Considering what this IC does, it is very complicated. I think they should have simplified the application by abstracting some of this rather than making it so directly coupled to the architecture.
hoyyoth
Joined Mar 21, 2020
531
Thank you very much.
May I know my led blinking frequency calculation is correct or not.
Led blinking frequency is[ (90+/-30)/60]Hz.
Regards
Jerry-Hat-Trick
Joined Aug 31, 2022
843
Given the relatively high unit price and complexity as well as having to use a surface mount device with so many pins I’d seriously consider using a 555 astable, even two separate circuits for left and right for simplicity and cost reasons.
LowQCab
Joined Nov 6, 2012
5,102
It would be much simpler to just use a standard Automotive-Turn-Signal-Flasher, and cheaper too.
The type that You need has 3-Terminals, not 2-Terminals.
You can get one for less than ~$5.oo.
eetech00
Joined Jun 8, 2013
4,724
Dear Team,
I need to design a LED turn indicator for two wheeler.
The standard requirement is given below.
I need to calculate the blinking frequency from the above spec.
Does that means my pwm frequency is[ (90+/-30)/60]Hz.
I will be using BD18327EFV-M for this application.
Regards
HARI
f=60/90=0.666667 Hz
p=1/f=1.5 sec
PWM is related to duty cycle.
50% duty is roughly p x 0.5=0.75 sec
What type of two wheeler?
hoyyoth
Joined Mar 21, 2020
531
This is an electric bike.
In the datasheet application example how they arrived the clock frequency 763Hz
eetech00
Joined Jun 8, 2013
4,724
The frequency was probably chosen to meet an automotive lighting standard.
You'll have to do some research to find out why 736Hz was chosen.
hoyyoth
Joined Mar 21, 2020
531
Fine.
But from that design requirement we need to drive the clock I believe
The PWM duty cycle is determined by the clock
