LED Control Plz help
desi.djay
Joined Nov 22, 2008
4
hey
i m doing a project on PIC18F452 and using Visual basic 6.0 to control the PIC
in the project VB will send a Byte to the PIC through a serial port and the PIC turn on a LED with that Byte
i have the sample of my old lab
(LIGHT
bsf PORTA,RA1
bsf PORTA,RA2
bsf PORTA,RA3
movlw 128
cpfseq SAVEBYTE
bcf PORTA,RA2
movlw 2
bcf PORTA,RA3
movlw 5
bcf PORTA,RA1
return)
so could u guys help me figure out to turn on a LED PORTA RA1 with one byte and. then turn it of with a different byte
and turn of POTRA,RA2 with a different byte. and so on... with assembly language or MikroBasic or MikroC.
plz help. me figure out this.
thanx.. :(
gvr_p
Joined Nov 5, 2008
6
read the byte in received buffer and send it to the portA. The on/off sequence can be manupulated in VB on PC and send it to controller.
Alberto
Joined Nov 7, 2008
169
One byte is composed of 8 bits so you can control up to 8 leds! send 0 to turn them all off send 255 to turn them all on.
1 led 1 on - all the other off
2 led 2 on - all the other off
4 led 3 on - all the other off
8 led 4 on - all the other off
16 led 5 on - all the other off
32 led 6 on - all the other off
64 led 7 on - all the other off
128 led 8 on - all the other off
With cobination number you can control all the 8 leds.
B0 var Byte
T9600 con 2
Led var PortA.1
NoByte:
Toggle Led
Serin portA.0,T9600,500,NoByte,[B0]
PortB=B0
goto NoByte
The above code in basic need to be translated in your mikrobasic (but it should not be too different).
Connect serial Rx to PortA0
Connect a led via 330 ohms resistor to portA.1
Connect 8 leds via 330 ohms resistor for each led to the IO of portB (one for each pin of 8 IO port)
Send a byte via your PC and the leds should show up.
Alberto
desi.djay
Joined Nov 22, 2008
4
i did this code on mikro C but dont work..
int x = 200 ; // Code recieved from Computer
setup()
USART_init(19200); // initialize USART module
// (8 bit, 19200 baud rate, no parity bit...)
// Configure ports as OUTPUT
TRISA = 0 ;
TRISB = 0 ;
// Initiallize ports
PORTA.F0 = 1 ;
PORTA.F1 = 0 ;
PORTA.F2 = 0 ;
PORTA.F3 = 1 ;
PORTA.F4 = 0 ;
void main() {
//setup board
setup();
// Infinite Loop - continuosly run while powered on
do {
//if ( USART_Data_Ready() ) // if data is received
// x = USART_Read() ; // read the received data
switch(x)
case (1):
PORTA.A1 = 1 ;
PORTA.A2 = 0 ;
PORTA.A3 = 0 ;
break;
case (2):
PORTA.A1 = 0 ;
PORTA.A2 = 1 ;
PORTA.A3 = 0 ;
break;
case (10):
PORTB.A1 = 0 ;
PORTB.A2 = 0 ;
PORTC.A3 = 1 ;
break;
} while (1); //end do->while
Alberto
Joined Nov 7, 2008
169
I can't help you with mikroC. The only suggestion is slow down the baud rate. Set the port at a low value at the begining than when the system works, you can increase the speed till the system works .
Alberto
desi.djay
Joined Nov 22, 2008
4
thanx alberto . ...
i tried all i could with. mikro c but no luck so im going with assembly language cuz i can get it to at least talk pc and turn on one light with the code i have on my first post. if u kno any thing assembly and could help i would really appreciate it.
thanx
Alberto
Joined Nov 7, 2008
169
Can you tell me which is the frequency (in MHz) of the quartz or resonator of your circuit ?
Your pic is a 40 pins ?
Are you using a max232 for the serial connection to your PC or a simple resistor
Alberto
desi.djay
Joined Nov 22, 2008
4
yes its a RS232 serial connection
same as this pic and circuit board http://www.picbook.com/
it has a 10Mhz maximum oscillator speed
4 independent timers
17 interrupt sources
and the PIC pins
Total Pins are 40
and I/O pins 33
I/O PORTs 5
1536 Byte ram
16384 program memory 16bit word
