Completed Project LED circuit
ronsimpson
Joined Oct 7, 2019
4,795
Is this just computer simulation or are you going to build a real circuit?
Real circuit:
You will need a signal source. Do you have a nS signal source?
C1 will slow down the signal. I think it should be removed.
Deleted member 115935
Joined Dec 31, 1969
I'll just add,
if your drivng a 200 ps pules , for a blue led your going to need a good 3 plus volts.
obviosuly you will not see a ps pulse of light,
Taking a step back.
If this was nicely defined logic , driving a nice matched impedance line, into a nice resistive load,
then its hard to make a square 200 ps pulse ,
Just think about the volts per second rise / fall time you need, say with a 10 ps rise time of 1v, you need 100000 volts per micro second rise time. Which is quiet interesting .
If you think of what your driving, is Highley inductive / capacitive depending at what voltage your at.
its a very horrible load to drive into.
In your real circuit, your going to be very constrained by the layout you use. No wires for instance.
Good luck,
Papabravo
Joined Feb 24, 2006
22,116
Dear Eric,
We can't make V(vp) pulse in picoseconds ?
Probably not with the circuit parameters you have chosen. Do you suppose the guys that wrote the paper have some kind of "secret sauce"?
The simulation models or the real components they have just might be different enough if they claim they can do it. Maybe you have misunderstood or misinterpreted their claims.
Papabravo
Joined Feb 24, 2006
22,116
If I was going to try to duplicate this result I would be thinking about using 0402 resistors, controlled impedance microstripline connections and components, and a very carefully chosen NPN transistor characterized on a VNA. Even then the results might be disappointing. In this kind of circuit, unrecognized or ignored parasitic elements are everything.
I would say that @ericgibbs did a bang-up job of getting close to the mark.
ericgibbs
Joined Jan 29, 2010
21,552
hi,
In my commercial laser rangers I used a triple junction 25W laser diode, which was driven by a ZTX451 transistor in avalanche mode.
Best I could get was about a 5nSec rise time on a 15nSec pulse,, maximum range 5000 mtrs.
If you build the circuit, consider if there is any eye safety requirement.
E
schmitt trigger
Joined Jul 12, 2010
2,204
Why are you only using a 5 volts supply, whereas the paper you linked clearly mentioned that the circuit relies on the avalanche characteristics of a transistor?
Meaning several tens of volts?
From the paper;
“A voltage exceeding the collector-emitter breakdown voltage of the transistor is applied to the VCC terminal of the circuit.”
Papabravo
Joined Feb 24, 2006
22,116
From the paper;
Sounds like "secret sauce" to me.
Audioguru again
Joined Oct 21, 2019
6,826
Eric, your simulation seems to be using an ordinary 0.7V diode instead of a 3V blue LED.
A 3V blue LED will not conduct 0.5A with only 0.8A across it.
I saw the 2N2369 extremely fast transistor in the article. its max allowed Vce is 40V. The article used a supply up to 24V.
ericgibbs
Joined Jan 29, 2010
21,552
hi agu,
I just used the generic LED and NPN transistor in order to show a simulation for the TS.
With such a low Vcc of 5V, the circuit is not viable, requires at least 24v and decent Blue LED.
I tried the sim with a 2N2369, it was useless, it maybe a poor model limitation.
Interesting to know what is the TS's practical application or is it just a sim.??
E
Beau Schwabe
Joined Nov 7, 2019
186
Instead of relying on an RC constant and current variations in the LED/transistor, perhaps an "old school" approach might be applicable here .... since light travels at just under 1 ns per foot (11.8 inches per nano second), your looking at a distance of 2.36 inches for a 200ps window. If you send a pulse on a wire and have two taps located 2.36 inches apart driving a XOR (probably needs to be a descrete XOR to handle the speed), then theoretically you would have a 200ps pulse on the output of the XOR. Note: because of propagation delays in components and the tapped signal wire itself, you will need to initially adjust the tap locations, but it will at least be a starting point.
