Thanks for ur answer
Probably not with the circuit parameters you have chosen. Do you suppose the guys that wrote the paper have some kind of "secret sauce"?Dear Eric,
We can't make V(vp) pulse in picoseconds ?
Sounds like "secret sauce" to me.Why are you only using a 5 volts supply, whereas the paper you linked clearly mentioned that the circuit relies on the avalanche characteristics of a transistor?
Meaning several tens of volts?
From the paper;
“A voltage exceeding the collector-emitter breakdown voltage of the transistor is applied to the VCC terminal of the circuit.”
time of flight measurements are all the rage. 200ps should bring 60mm resolution if the trigger to emission time is very consistent.What will such a brief LED pulse be used for? What will you use to detect any response?
