LCD driving techniques
casdsys
Joined Mar 15, 2009
10
Hi all.
I hear you need to apply a square wave when using a lcd display.
Im using a 4543 type chip.
Question is, do I need to apply and square wave to the
4543
the back plane of the lcd ( common/gnd )
or both
if both does the square wave need to be in sync or opposing/inverted to each other.
Cheers.
ErnieM
Joined Apr 24, 2011
8,415
What joey said. Also, the phase between the two square waves is what makes a pixel on or off, typically opposite phase turns them on..
JohnInTX
Joined Jun 26, 2012
4,787
What Joey and Ernie said plus its vital that there be no DC offset in the driving waveforms. That will cause plating from one electrode to the other and ruin the display.
AN658 from Microchip is an excellent introduction to LCD technology. The few code examples are for PICs but the rest applies to any LCD application.
casdsys
Joined Mar 15, 2009
10
Thankyou for your input. I will apply a square wave to both, LCD common and the phase pin of the 4543 using a 741.
ian field
Joined Oct 27, 2012
6,536
Hi all.
4543
or both
Cheers.
I don't remember the exact details, but a popular scheme shown in many text books is to drive the segments via an XOR gate - if you feed a pulse train to one input, the logic state of the other input determines whether or not the XOR inverts the pulse train.
Therefore; with one logic level, the pulse train is in phase with the backplane drive and the segment is not active. Change the logic level and the pulse train is inverted to out of phase with the backplane and the segment becomes visible.
RichardO
Joined May 4, 2013
2,270
A common op-amp (such as a 741) will not output proper CMOS logic levels. You need to use a CMOS inverter (sucha sa a 74C04), instead. The CMOS inverter will also take way less power than an op-amp.
ian field
Joined Oct 27, 2012
6,536
The most important thing is; not to leave steady DC across any LCD elements.
casdsys
Joined Mar 15, 2009
10
OK , so now I ask is I guess there would be no harm in using a simple low cost 8pin microprocessor dedicated to just generate the 50/50 ratio square wave??
Does 30Khz sound fine?
32,844
You can do it any number of ways. What are you driving the 4543 from? If it's an MCU or anything similar, why not have it generate the necessary square wave?
As to the frequency, that will depend on the LCD in question. Most direct-drive displays are run at much lower frequencies, like 30Hz to 100Hz. The faster you run them the more power they will consume and the more crosstalk you will have between segments.
casdsys
Joined Mar 15, 2009
10
I have a 2 digit LCD display connected up to a couple of 4543.
1). The main MCU will control the strobe ( 2 lines for the 2 x 4543, 1st digit and the 2nd digit ) and 4 lines for the ABCD lines, paralleled between the 2 x 4543. and 1 line to generate the squarewave.
2). Or I can use a 8pin MCU just to produce the squarewave.
3). Or as (2) plus 2 lines to sense UP/DOWN button and 4 lines to output the ABCD.
32,844
There are many ways to do most things. You need to decide what makes reasonable sense within the context of the overall project, your resources, experiences, and capabilities, and what it important and what is not.
