Latching Comparator
mshalash
Joined Dec 27, 2012
13
Hi All
Latch Comparator
Kindly advise on this problem
I am trying to implement a circuit to shut down power using LM311 comparator and P-Mosfet
but getting nowhere.
see the schematic attached.
Alec_t
Joined Sep 17, 2013
15,156
Welcome to AAC!
Do you want to shut down power when the input signal goes above Vref or below Vref?
Will the comparator still have its power supply after shut down has occurred?
ericgibbs
Joined Jan 29, 2010
21,577
hi m,
This is a circuit for LTSpice from your image.
We need to know the voltage levels.
E
Added 2nd Plot with PMOSFET
mshalash
Joined Dec 27, 2012
13
hi msh,
Welcome to AAC.
What are the voltage levels on your circuit.?
E
Thanks for your response
it is 7 to 8.4 v (2 x LI-On batteries 3.7v each in series) and the signal should be less than the V ref (1.24V) above which should cut off and latch
mshalash
Joined Dec 27, 2012
13
Welcome to AAC!
SHut down above V ref (1.24v) and LM311 will still have power after shutting down +v on load only
ericgibbs
Joined Jan 29, 2010
21,577
hi m,
It works as your initial post, a circuit to shut down power using LM311 comparator and P-Mosfet
Please define what you mean as latching, I need a little more information.
E
mshalash
Joined Dec 27, 2012
13
hi m,
E
I mean it shuts the load +ve when the signal goes above V ref and keeps it shut even when the signal goes down to less than V Ref
ericgibbs
Joined Jan 29, 2010
21,577
hi m,
The circuit I posted was not designed to remain shut when the Vsignal falls below 1.24V
E
