Latch with NOT gates
screen1988
Joined Mar 7, 2013
310
I have a latch with NOT gates as in the picture.
Let's assume that initially, switch is connected to Vcc then I have:
Input of upper NOT is 1 (logic)
Output of lower NOT is 1
Now if I look at the upper NOT:
Because its input is 1 => its output Q = 0
Next consider the lower NOT:
I am confused about the two possibilities bellow. Which one is right?
1)
Because input of the lower NOT is Q = 0 (result from upper NOT)
=> its output \(\overline {Q}\) = 1
2)
Because output of lower NOT \(\overline {Q}\) = 1 => its input has to be 0.
I mean that it is output of the lower NOT that cause its input to be 0.
I think #2 is maybe wrong because the input of NOT isn't affected by its output but not sure.
35,280
You have to focus on cause and effect.
The cause is the INPUT.
The effect is the OUTPUT.
The circuit is called a bi-stable because it has two stable states.
It works because it is a positive feedback system, i.e. the input is reinforced by the output of the system. It will latch up to either logic LOW or HIGH when forced to do so.
Ramussons
Joined May 3, 2013
1,572
Let's look at it this way:
Output Depends on Input; Not the other way!
"I think #2 is maybe wrong because the input of NOT isn't affected by its output but not sure."
Your thinking is Correct. #2 is wrong.
Ramesh
22,115
You can't really build a latch with NOT gates. It forces you to connect an output (Q*) to Vcc or GND. That is a bad business, an output trying to short a supply to GND or vice versa.
Latches are almost ALWAYS built with 2-input NAND gates so the complementary outputs can be connected to gate inputs and outputs won't fight with switches wired to Vcc or GND.
I hope you were only simulating this circuit and not trying to use it to short your power supplies to GND!!
33,325
Actually, using cross-coupled inverters as an SRAM cell is common practice in CMOS IC design. There are many variants. Sometimes you use a weak inverter for one of them that you can easily overdrive with a tri-stated data signal. We commonly used an NFET on each output and would turn on whichever signal we wanted taken LO. Frequently you buffer the output to prevent follow-on circuits from upsetting the latch, but sometimes you just don't have room for that and so you carefully design how it interacts with the follow-on circuits.
33,325
It some ways its actually less silly than the notion of an open-collector output when you think about it (at least think about it in a certain way). In the case of an open-collector output you have a device that is trying to assert a HI (the resistor) and you overdrive it with a device that can assert a LO more strongly (the gate output). But both devices remain in contention for the entire time that you are asserting a LO. In this case, you have a device that is trying to assert one logic level (an inverter) and you overdrive it with a device that can assert a possibly different logic level more strongly (the supply). The difference here is that the inverter responds immediately to agree with the overdriven signal and there is no longer any contention.
screen1988
Joined Mar 7, 2013
310
Can you explain the reason for this?
Do you refer to the case when input is floating?
33,325
You need to read the whole thread more carefully. This is addressed in some detail. Do that and then, if necessary, ask for specific clarification on points that are still unclear.
22,115
No, my point was that the alternative of using 2-input gates to make a latch exists, and avoids the problem of connecting an output to either Vcc or GND.
The counter opinion is that the momentary fault is of no particular concern and that a latch built with inverters is a "???" practice. I'm not sure what word to use in this context.
35,280
I have no concern with using two NOT gates in this fashion and I have seen it used to debounce SPDT push-buttons on commercial/industrial instruments.
Edit: Except the push-button is wired differently. The center connection is wired to ground and the two contacts are wired to the inputs of the two inverters.
screen1988
Joined Mar 7, 2013
310
I have re-read many times but I almost have no idea what you are trying to say.
Here is a latch from NOT gate:
And I think here is the circuit that Jony suggest:
Could you tell me where the problem you are talking?
33,325
"???" => "common and accepted"
would be my best offering.
22,115
Those words were never applied to such a concept in my experience with traditional TTL. Maybe things are different now on chips. I have seen chip designers do unusual things, for sure.
