Latch Comparator - 0.264V above 1.65V or below 1.65V
mriksman
Joined Aug 31, 2010
113
I want to use a current sensor IC (like the AC712), but a Chinese one CC6903-10A because it works with 3.3V. There is a circuit in the ACS712 datasheet (page 12) which also appears in the CC6903 datasheet (page 5, middle/bottom right) that is meant to latch when a high current occurs.
Now, Vout equation is Vcc/2+0.132*I.
So 0A is 1.65V, -10A is 0.33V and +10A is 2.97V.
I'd like to trip/latch when the current is -2A or +2A. I mean, I assume that's how it will look when monitoring an AC load right?
Once tripped, it should latch until power is removed from Vdd.
My LTSpice does not seem to indicate this is what would happen...? It seems to reset itself?
Anyone able to help me with a simple latch?
1.65V is good.
Anything above 1.914V is bad.
Anything below 1.386V is bad.
mriksman
Joined Aug 31, 2010
113
Bonus points - any circuit ideas so that when the circuit above has tripped, either Vpulse is stopped, or power is cut to the AC load (a dimmable LED or incandescent globe)
eetech00
Joined Jun 8, 2013
4,751
1.65V is good.
It's been a while since I built mine, but if I remember correctly, the sensor output will always be a DC voltage that reflects the sensor sensitivity when detecting AC or DC current. I'm not sure whether the DC output value is reflects AC peak or AC RMS current (I think its peak).
Post your LTspice .asc file and model file(s) if any.
mriksman
Joined Aug 31, 2010
113
Thank you all for replying.
@eetech00 The sensor output is linear between 0.33V and 2.97V, which indicates a current of between -10A and 10A. 1.65V=0A. But forget about it being a current sensor, just treat this exercise like I have an analog voltage signal. 1.65V is 'normal. Anything above 1.914V is bad. Anything below 1.386V is bad.
@LowQCab I looked around for an IC that had the FAULT latch built in. But I couldn't find any that met my requirements.
* Must be cheap (like the Chinese one I found; $0.90).
* Must be isolated. I have multiple back-to-back MOSFETs, so they need to be isolated from the uC signals.
So the only way forward I have found so far is implementing my own FAULT latch.
Plus, it'd be a great thing to learn I think; using comparators/op-amps.
@crutschow Always glad to see your name pop up! A veteran among these forums.
I tried flipping the diode - it made things worse.
What is interesting is, it 'works' as long as the Vout(sensor voltage) never gets below the Vf of the diode ~0.7V.
0.7V corresponds to a Vout of ~ -7.2A. But that seems like a poor design; it trips at 2A, and then when the AC waveform spins around, it resets at -7.2A. Now, granted this FAULT should have killed the power and thus it should never reach -7.2A, but, I still feel like this is poor design. Surely there are better ways to latch.
Also; I guess tripping on just the positive 2A is OK? Or I could implement a Window Comparator. My issues are still;
* How do I latch
* The best way to kill the back-to-back MOSFETs driving the Load; kill the drive gate signal? Or cut the AC to the Load completely with another MOSFET (although, I don't have much PCB space for another MOSFET).
Alec_t
Joined Sep 17, 2013
15,167
How about this?
Q1 pulls the comparator input lower than a diode would. Q2 shorts the opto-LED.
Comparator choice is not critical (LT1711 was selected randomly, for its low supply voltage spec).
Edit:
Actually, if you did choose the LT1711 (or similar) the circuit would be simpler, because it has an internal latch which could be used, as below.
Edit 2:
This would also allow Q2 to be replaced by a PNP transistor in series with the opto-LED to shut off the LED current. The PNP base would be driven, via R4, by the inverting output of the LT1711.
mriksman
Joined Aug 31, 2010
113
@Alec_t Awesome - you're the second name I was waiting for haha.
Your schematic works. However, why the LT1711? I tried the LT1017 and LM393 with no luck. I am particularly interested in getting the LM393 to work because it is cheap/'basic component' on the Chinese PCB site that does SMD placement.
I am also wondering if it possible to do a 'Window Comparator'? I have read that, although rare, a failure can occur in one polarity. So overcurrent could occur to the negative side.
I have spent a few hours playing around, and I am worried about the initial power up. The current sensor Vout will probably start at 0V and quickly go to 1.65V (no current, I=0A). But in that brief moment it is below the low trip point, it could cause the FAULT latch to trigger...
How could you do a Window Comparator, but delay the latch circuit for a few micro or milli seconds to allow Vout to stabilise first?
Thanks for your help all.
mriksman
Joined Aug 31, 2010
113
Did you see my two edits in post #7?
I did thanks, yes - but my query still stands. I tried a LM393 and LT1017 and neither of them worked. The PCB site doesn't have an LT1711 available in their available parts list, so I am trying to use one of their available components; particularly the LM393 if feasible. But I'd like to validate it on LTSpice first.
sghioto
Joined Dec 31, 2017
8,763
The 1.65vdc level will not change using AC current you need a peak detector to extract any voltage difference.
The output from the sensor will look like this.
mriksman
Joined Aug 31, 2010
113
This is with the LT1017.
If you have the massive 'ZZZ' library there is the LM393 in there as well. It too, doesn't work.
Edit: Sorry - R4 needs to be 100k. It REALLY doesn't work with 10k. Have updated ASC file.
This is with LT1017
This is with LM393
And working correctly with LT1711
mriksman
Joined Aug 31, 2010
113
mriksman
Did you read my post #12?
Yes. But I don't think I understand.
This is what Vout from the current sensor will look like right?
I am feeding that into the non-inverting input of the comparator. As soon as the comparator sees 1.65+2*0.132=1.914 (which is derived from the voltage divider), the output of the comparator should latch. Which is what alec_t and crutshow are helping me with.
mriksman
Joined Aug 31, 2010
113
Yes but the DC portion does not change when measuring AC current meaning the comparator will not activate.
I’ll be honest. I have no idea what you’re talking about.
I am pretty sure that the Vout on that CC6903 current sensor will be a sine wave, centred around 1.65V.
And if that goes too high, I want to trigger/latch.
