L298N Motor Module with Arduino Mega doesn't work.
Ravdev
Joined Feb 7, 2020
18
Hi, I have a project which uses an Arduino Mega board, L298N Motor Module, 2x 12-volt DC Motor and 3x 18650 Li-ion Battery. I uploaded the code to the Mega board, connect the wires and place the battery, but the 2 DC Motors seems to not rotate. Does anyone have any idea how to solve the problem?
bertus
Joined Apr 5, 2008
23,009
As drawn the 3 batteries are parallel, giving about 4 volts
For 12 volts you want them in series.
Bertus
Ravdev
Joined Feb 7, 2020
18
Bertus
Hi, I think it is in parallel, I am using a 3x 18650 battery holder. But do I need more? Do I need 8x 18650 batteries overall?
Edit: I used 3 1x 18650 battery holder because I couldn't find a 3x battery holder for fritzing.
Alec_t
Joined Sep 17, 2013
15,156
I don't know the details of your motor driver board, but I'm guessing the ENA and ENB inputs need to be jumpered to +5V?
Ravdev
Joined Feb 7, 2020
18
It is the L298N Motor Driver, I don't have any wires connected to the ENA and ENB. Do you mean by connecting it to the 5V of the Arduino Mega?
shortbus
Joined Sep 30, 2009
10,049
Like Alec said - "Next are the logic control inputs. The Enable A and Enable B pins are used for enabling and controlling the speed of the motor. If a jumper is present on this pin, the motor will be enabled and work at maximum speed, and if we remove the jumper we can connect a PWM input to this pin and in that way control the speed of the motor. If we connect this pin to a Ground the motor will be disabled" From - https://howtomechatronics.com/tutor...dc-motor-control-tutorial-l298n-pwm-h-bridge/
dendad
Joined Feb 20, 2016
4,641
The supply for the motors needs to be VinHI + 2.5V according to the data sheet. So it will not work on 3.7V. Put the batteries in series.
Ravdev
Joined Feb 7, 2020
18
I need to make them rotate. I don't need to control them.
AlbertHall
Joined Jun 4, 2014
12,653
Ok, that sure looks like they would be in series.
But your original picture shows them connected in parallel so we were confused.
ebeowulf17
Joined Aug 12, 2014
3,307
Sorry, I'm confused. But to make it short and not confusing, I'm using a 3x 18650 battery holder.
Edit: The picture of the battery holder is in the attachment.
Do you have 11-12V, or something in that general range at the output of the red and black wires? If so, you're in good shape there.
You still haven't answered earlier questions about the enable pins. Do you have jumpers in place, connecting the enable pins to their neighboring 5V pins? I don't know this driver board myself, but based on comments and documentation above, you need to make those connections.
Ravdev
Joined Feb 7, 2020
18
Do I need to connect them to a PWM pin?
