L298N can't run motor (LTS Simulator) ..#2
opampppp
Joined Dec 17, 2022
7
Hi
Maybe this will help.
SW is a center-off switch.
When top contact closes, motor turns in forward direction.
When bottom contact closes, motor reverses direction.
When SW is in center position, motor stops.
eT
Hello, which software is this?
i am using ltspice but i cant find l298 in ltspice.
thanks
Papabravo
Joined Feb 24, 2006
22,111
thanks
It is definitely LTspice. Although the specific model you are interested in my not be in the install package you can certainly find one with a bit of searching.
