KiCad circuit simulation gives unexpected results
kennelh
Joined Jun 6, 2025
Hopefully someone has some insight for me. I came across this post which addressed my exact problem, except my situation needs different threshold voltages for the battery. I created a KiCad schematic, got the Spice model for the TLV431, and did a simulation. It "works", but the issue I'm finding is the threshold for reference voltage is much lower than 1.24V, more like 1.01V. Could this be something specific to Kicad, or is there something else I'm missing?
38,913
Hard to tell with such little info.
My crystal ball is a little cloudy, so could you post a screen-grab of your KiCad schematic?
What battery threshold do you want?
kennelh
Joined Jun 6, 2025
Thanks. Here's the screenshots of the schematic, and simulation results showing V(ref) in red and I(R_Sim1) in green. I'm trying to get an off threshold of 12.4V and an on threshold of 12.6V, but if I can figure out what's the issue I can probably figure out the resistor values to do that. Thanks!schematic.pngsim.png
38,913
Your TLV431 model does appear to be faulty.
But I just realized the TLV431's cathode voltage is seriously exceeding its 7V max value in that circuit, so a TL431 needs to be used instead, which has 37V max rating and a 2.5V Ref value.
LTspice sim below:
