Hi,View attachment 307367
I tried KCL but I couldn't get the right value. When I use KCL should I accept the branchs that dependent current source in it current i0 or something else. I tried to accept it i0 but couldn't get the right value if I shouldn't what is the current in that branch
Hi,<snip>
It's the job of the original poster to show calculations. I just took the supposedly correct given answer and applied it back to the circuit to show that the given answer has problems.Well why did you not show your calculations?
Hi there,It's the job of the original poster to show calculations. I just took the supposedly correct given answer and applied it back to the circuit to show that the given answer has problems.
| R | Just having a bit of a current control problem. | Power Electronics | 49 | |
| M | Crossing within differential pair problem | PCB Layout , EDA & Simulations | 17 | |
| S | Boss DM-2 PCB problem | PCB Layout , EDA & Simulations | 9 | |
Filter problem | Analog & Mixed-Signal Design | 8 | |
| J | Help Drawing Circuit for Problem. | Homework Help | 15 |
