MisterBill2
- Joined Jan 23, 2018
- 28,296
The need for a load resistor exists on some versions of amplifiers that include an output transformer , and mostly those amplifiers with vacuum tube output stages. So it is not likely to actually NEED a load resistor for the original purpose, but certainly a load resistance will not be a poor choice. It will reduce whatever amplifier instability might happen from a no-load operation.I don't know why we need to "load" the amplifier output. Yes the amplifier might go non-linear without an expected load, but we only want to detect an output, not use it for audio purposes. And we'd be wasting energy dissipating it into heat, which we have to get rid of somehow....
My comment about the opto-isolator was based on thinking that the circuit shown in post #10 was an actual circuit. The fact is that the IC contains a great deal more circuitry than is shown. And usually I do not look up the detailed data sheets of components being discussed here. Typically that leads to getting all sorts of advertising emails.
For muting the jukebox in the event of a fire alarm condition, a suitable relay activated from the alarm sounder output could be the solution. The relay could switch off the mains power to the jukebox. If you go with the fire alarm sounder relay installation you will need a series diode so as not to upset the supervisory circuits. I discovered that when I added fire door release magnets in a building. Evidently it is OK because the alar system has passed the yearly inspection for ten years since the installation.
