Issue in MOSFET
m_np
Joined Mar 13, 2023
17
1684237116819.png I am designing 24V_5A SMPS circuit by keeping reference of a mobile charger circuit...when I power on the circuit the IRF840(power Mosfet) blasted . What is the reason...Is there any mistake in the circuit diagram..?
Dodgydave
Joined Jun 22, 2012
11,395
The Mosfet isn't getting a turn off signal and is practically shorting out the supply via the primary winding, where did you get this circuit from?
m_np
Joined Mar 13, 2023
17
Mosfet is getting its turn off signal via bc547 transistor(which would turn off through current sensing resistor)
Ian0
Joined Aug 7, 2020
13,315
We have not used optocoupler for voltage regulation....instead we have opted for LM338 regulator
in the absence of regulation, a flyback circuit transfers the same amount of energy each cycle, increasing the energy stored in the capacitor, and increasing its voltage until something fails.
m_np
Joined Mar 13, 2023
17
Is it ok to use lm338 instead of optocoupler as both are doing the same function?
Irving
Joined Jan 30, 2016
5,195
This design relies heavily on the -ve feedback from the Aux secondary winding and the combination of the BA159/47u/2k2, whereas you just have an 1N4148 shorting out the feedback winding. Your feedback winding polarity relative to the output winding polarity is reversed - I suspect you aren't getting the feedback turn-off pulse this circuit requires. Did you wind the transformer yourself or are you using an off-the-shelf one?
Irving
Joined Jan 30, 2016
5,195
No they aren't - the optocoupler plays a key role in capping the voltage generated at the secondary whereas your approach will see significant open-circuit voltages developing at the secondary especially on low loads.
Martin_R
Joined Aug 28, 2019
137
Looking at the reference circuit, there's a 3 turn winding which feeds back to the gate of the MOSFET to switch it off. Notice the dot on the winding, denoting the correct phasing (important on all windings).
Without that secondary I can't see how the circuit would oscillate correctly.
Dodgydave
Joined Jun 22, 2012
11,395
No, the reason why they use an optocoupler is to isolate the output from the primary side, and it's a faster way to switch off the transistor.
Your circuit doesn't have any voltage feedback regulation , so the fet will oscillate at maximum output and then burn up.
Ian0
Joined Aug 7, 2020
13,315
This is the final circuit with regulator
On low load the voltage at the input of the LM338 will keep increasing until the LM338 (or the capacitor) fails.
Another point is that the LM338 is a linear regulator - any excess voltage will be dissipated as heat, making it rather pointless to use a switched-mode circuit in the first place.
schmitt trigger
Joined Jul 12, 2010
2,288
Let’s talk about the elephant in the room: the design of the flyback transformer.
You have not discussed, at all, the transformer details. A line-powered flyback transformer design is FAR from being trivial. More so if you choose a self-oscillating topology.
Ian0
Joined Aug 7, 2020
13,315
Agreed. Why try to get a self-oscillating circuit working when there is an almost infinite choice of control ICs?
