I was given a 1:1 isolation transformer that I wanted to use for some measurement equipment that I have been using. I was going to use a common outlet and connect it directly to the primary and similarly connect the secondary to another outlet. From what I understand I need to pass the ground from the primary to the secondary.
I was wondering if I should or shouldn't also connect the ground straight to the neutral on the load outlet? It makes sense to me, but I don't know if there is a better way.
