- Joined Jan 23, 2018
- 28,593
Once again, the sole purpose of an isolation transformer is ISOLATION. That implies breaking ALL of the connections between the input side and the output side.
Now consider that most, deadly shocks are the result of contact with a single live conductor and "ground", the other side of that voltage source. In an effectively isolated system, then, contact with a single live conductor does not lead to any current flow, since there is no completed circuit. The result is no real shock. Of course, if some unknowing individual breaks the isolation by connecting some part of the isolated system to that ground, a shock will result, because the circuit is no longer isolated.
