You mean by control current =when voltage vary current vary to give same power .....i which type create wast heat ??and in which part of driver ??If you mean, why use isolated psus instead of non-isolated ones, because isolated types are safer to use, they can control the current, whereas non-isolated is cheaper to produce and doesn't create wasted heat.
