isolated dc/dc booster
clark.kent156
Joined Aug 17, 2019
52
Hi. I have a project with a voltage output, dc, of 10v 100mA. I'm looking for an "isolated" booster to increase the voltage. Can you provide some links where I can search for this? I'm not having much luck. TY.
SamR
Joined Mar 19, 2019
5,512
What is your final voltage and current requirements? If you are starting with 10V @ 100mA you do realize that the current must drop as voltage increases? Not a lot of overhead to work with for 100mA...
clark.kent156
Joined Aug 17, 2019
52
Thanks for the response so quickly. I do realize that, thanks for pointing it out anyways. It's mostly going to be testing at this point. Can you provide some links to point me in a good direction?
