I have a 5 series cell lithium battery pack I want to charge/balance by charging each cell individually while the pack remains in series.
To do this I am using a single cell charger chip MCP7381, 5 of them. Datasheet is here:
http://www.microchip.com/mymicrochip/filehandler.aspx?ddocname=en528273
To keep the circuits from interacting I have 5x MEU1S0505ZC isolated DC/DC converters to feed each charging chip. You can find the data sheet here:
http://power.murata.com/data/power/ncl/kdc_meu1.pdf
Each charger set has two capacitors, one on the input and one on the output, then a 5.1K resistor to set the charger current at ~200ma
Here is a rough drawing of the circuit:
Here is the completed board I made:
SO I got all soldered up and as I connected to last cell I accidentally made a short which I believe caused a cascading failure but I am not sure. I am worried the short was not the source of my failure and instead I may have had a common mode voltage that may be cooking the charger boards.
Do you see any issues with my circuit drawing?
