Is Voltage divider enough?
AnalogKid
Joined Aug 1, 2013
12,300
1.5 V is the typical forward voltage of the LED, not a power supply requirement. The datasheet says the max current is 100 mA. First, determine what current you want to push through the LED. Second, use Ohms Law to calculate the series resistor for the LED.
That was all guesswork. Until you post your schematic there can be no real answers.
ak
pjreijiri
Joined Aug 19, 2015
117
This is my schematic.
Would the voltage divider work in this case?
The 15ohm resistor with the 1.5V gives me 100mA
WBahn
Joined Mar 31, 2012
33,365
You would need to take into account the equivalent resistance of the voltage divider itself. Let's say that this somehow worked an you got 100 mA flowing through the 15 Ω resistor. Where is that current coming from? Since it has to be coming from the 5 V supply, it has to be flowing through the 1.5 kΩ resistor. But that means that the voltage drop across that resistor is 150 V. Seems a bit unreasonable, no?
You are abusing Ohm's Law by picking some voltage and dividing it by some resistance to get some current. But Ohm's Law requires that the voltage you use be the voltage across THAT resistor, not just the voltage on one side of it.
But you don't need the voltage divider. If you want 100 mA then you need to put a series resistor between the LED and the 5 V supply that drops 3.5 V across it when it has 100 mA flowing through it. The other 1.5 V will be dropped across the LED.
WBahn
Joined Mar 31, 2012
33,365
I would not recommend running it at 100 mA. That is the absolute max continuous current that it is spec'ed to tolerate. If you are only pulsing it for short durations with plenty of time between pulses, you would probably be okay. But if you are going to run current through it for long periods it looks like the optical specs were tested at 20 mA, so that is probably a more reasonable operating point.
dl324
Joined Mar 30, 2015
18,524
Why would you want to operate the LED at 100mA? That's the absolute max parameter. Reliable designs don't operate components at their absolute max parameters.
If you want to use a resistor divider, the current in the divider needs to be at least 10X the load current. If you do the math, you'll see that for a 100mA load, a divider isn't a good solution.
WBahn
Joined Mar 31, 2012
33,365
What do you suggest then?
It has been suggested twice to just use a series resistor to limit the current in the LED to the desired level.
I specifically told you to size the resistor so that it drops 3.5 V when the desired current is flowing in it.
I specifically suggested that you use 20 mA and not 100 mA.
Are we just wasting our time?
panic mode
Joined Oct 10, 2011
5,488
read the data sheet... know the limits and stay within them. right after absolute max parameters is info on typical parameters and it tells that Vf = 1.5V , If=20mA
dl324
Joined Mar 30, 2015
18,524
The datasheet suggests a maximum sensing distance of 6cm. What do you require? That distance and the reverse voltage on the detector will be factors in determining an appropriate current in the LED.
Will you be conditioning the signal for the microcontroller? Is it a digital input?
AnalogKid
Joined Aug 1, 2013
12,300
You do not need a voltage divider to drive the LED. With the cathode tied to ground, a single resistor to the +5 V is enough. Look at the datasheet for the *typical* operating current, and calculate the resistor value from that.
ak
bertus
Joined Apr 5, 2008
23,041
For temperature reasons, keep the current well below 50 mA.
To calculate the resistor for the led at 5 Volts @ 20 mA, you would see a forward voltage of the led of about 1 Volt:
The needed resistor will be (5 Volts supply voltage - 1 Volt led voltage drop) / 20 mA = 200 Ohms.
Taking 180 Ohms, the current will be a bit higher, taking 220 Ohms, the current will be a little lower.
Bertus
ian field
Joined Oct 27, 2012
6,536
Using the divider just makes the maths more complicated - all you need is to calculate a suitable value for a simple series current limiting resistor.
Is there any particular reason the data sheet shows PWM drive?
The PWM circuit shown includes a current limiting resistor - that will need higher resistance if you feed the LED steady DC.
pjreijiri
Joined Aug 19, 2015
117
Bertus
Thank you for taking the time to explain it in an easy matter.
So it should be something like this?
AnalogKid
Joined Aug 1, 2013
12,300
Two things. First, that circuit takes all the fun out of growing the functions from scratch. Second, that package is more difficult than most surface mount packages to solder by hand. Other than that, it obviously is the right part for the job if your application can stand the time delay caused by an integrating detector.
ak
pjreijiri
Joined Aug 19, 2015
117
ak
hahaha yes I know, but sometimes you have to keep it simple and make sure to really have something working.
As for the soldering, it won't be done by hand.
