Is this component an SCR?
Rahulk70
Joined Dec 16, 2016
538
Found this circuit board from an 1980s old humidity controlled chamber. This definitely looks like a temperature regulator of some sort. It has a M logo which means made by Motorola. It has the labels E03G-3-9 and 8739. Does anyone have any info on what this part is?
Thanks in advance.
schmitt trigger
Joined Jul 12, 2010
2,279
Those stud packages were very commonly used for both SCRs and Triacs during the 70s and 80s.
8739 is the manufacturing datecode:
The 39 week of 1987.
Unfortunately the other numbers are house numbers, they don’t follow the Motorola’s catalog part numbers for thyristors; MCR, MAC, HEP or a JEDEC 2N-xxxx
28,522
The device has numbers, and possibly letters, and maybe even a trademark. Those will provide information that may even lead to a data sheet. The exact same packages could have an SCR, a triac, or a transistor.
Just be very careful with the force applied to the terminals because that glass seal is prone to breaking, and then you have a chunk of scrap metal.
Rahulk70
Joined Dec 16, 2016
538
What the reason for query?
Is the unit not working?
Max.
Yes, it was removed from a functional unit. But because the machine itself was from the 80s it was to be discarded. So, I salvaged some parts that I found useful. You are right it is an SCR.
Rahulk70
Joined Dec 16, 2016
538
I thinks a Motorola Case 253-03 style SCR (stud version). So, after some digging found the shorter lead is Gate, long is cathode and body is Anode. After feeding the Gate-cathode with a 1.32V from a NiMH cell via a 10 ohm resistor I was able to get the Anode to cathode to conduct. Without the battery connection it doesn't conduct so confirmed. Thank you so much for the information.
Though I wish I could find the datasheet to determine the voltage and current specifications for the Thyristor/SCR.
Rahulk70
Joined Dec 16, 2016
538
You mean the portion of the thyristor where the gate-cathode is attached is glued with glass?
Rahulk70
Joined Dec 16, 2016
538
YES, that shiny colored section on many of the devices is a glass hermetic seal. Some brands may use epoxy of some kind, but many of them have glass hermetic seals
Glad you mentioned it because I had a hard time getting the SCR out for the picture. In case I decide to pull it out in the future I'll be careful. It could be glass I have a feeling. Looks very glossy.
