In this case "ok" means 17 to 18 volts. Minimum. Under load too, least you need the LDO type that is in there now.Center pin is ground.
I tried another as the board has a couple and it is a 15V Regulator.
Input is OK so I believe any 15V will do.
Thanks guys.
