Is there a TTL-to-RS232 Level Shifter that allows me to select the output either TTL or RS232
tonytnguyenn
Joined Feb 8, 2022
7
Hi everyone,
I am looking for a TTL-to-selectable-TTL-or-RS232 level converter IC. Essentially, my host outputs UART TTL, but the UART client can expect either TTL or RS-232. I cannot find a TTL-to-RS232 level shifter that has an enable pin allowing me to select the output is TTL or RS232.
Thank you for your advice!
tonytnguyenn
Joined Feb 8, 2022
7
MAX232 IC.
Thank you for the suggestion. I went over the datasheet of MAX3223 since I am using a 3.3V microcontroller. If I feed the UART TTL to the TTL/CMOS INPUTs, the MAX3223 IC will output both:
TTL out (looks like this output TTL will be inverted signal from the input TTL?​
RS232 signal​
Am I understanding this correctly?
Ya’akov
Joined Jan 27, 2019
10,226
Why would you want to select TTL on a TTL to RS233 converter?
If you want TTL then toss out the converter.
I think the TS would like a "passthrough" mode so the level shifting could be turned on and off without the complication of bypassing using external components.
[EDIT: reworded]
dendad
Joined Feb 20, 2016
4,636
Having the levels selectable could be a recipe for disaster.
I can just see the RS232 levels sent into a TTL input and damaging it.
A good idea is to have different connectors for TTL and RS232 to avoid that.
I agree with @MrChips in post #6.
I cannot really see a problem, just add the converter when needed.
