Is there a npn transistor substitute for a LM386 amplifier?
Adam Monarch
Joined Mar 17, 2019
68
I am looking for a npn or pnp transistor substitute for the Lm 386 amplifier chip which powers a 8 ohm 1/2 watt speaker.
The reason that I want to make this switch is for cost, easier to solder to pref board, and less time to assemble and solder.
The lm386 is a good amplifer, however I want to reproduce the amplifier circuit using transistors, preferbly less that 2 transistors.
Adam Monarch
Joined Mar 17, 2019
68
Would using mosfets or jfets reduce the amount of components in the circuit to solder which functions like the lm386 audio amplifier?
atferrari
Joined Jan 6, 2004
5,031
Considering that your time has value, no matter how low, or how high for the case, and the fact that that you need to ask such a question you should forget your idea and move on to something more productive.
Adam Monarch
Joined Mar 17, 2019
68
ok thanks
Just to cover my bases, What other 8 pin amplifiers are equivalent to the LM386.
I am interested in persuing other options if possible for experimental purposes.
BobaMosfet
Joined Jul 1, 2009
2,211
ok thanks
I guess I'm curious, just how much does an LM386 cost you? They aren't expensive, and if it's a volume question, cost goes down as quantity of purchase goes up...
38,909
What is the reason for using something different?
Knowing that, we can make better suggestions, since there are many audio amp devices available.
mvas
Joined Jun 19, 2017
539
It comes in an 8 Pin DIP, 0.1" spaced package and sells for $0.35 each ( QTY 10 )
Why / How is that hard to solder on a perf board?
What could be "easier" to solder?
$0.35 each is cheap.
The complete amplifier kit, with circuit board and volume control, sells for $4.00
Adam Monarch
Joined Mar 17, 2019
68
I have containers of transistors that I bought quantity 840 components which cost me $20 and lm386 quantity 10 components costing $12.
Adam Monarch
Joined Mar 17, 2019
68
Soldering the chip to the pref board is not a problem. The diifculty for me is to solder the lead wires to each pin. I can do it but it is very time consuming for me. I could possibly use a special pef board which has 8 pin nodes which extends out each soldered pin to a larger surface area which might make it easier as well as less time consuming for me to assemble.
BobTPH
Joined Jun 5, 2013
11,665
If you are going to be assembling a lot of them, make a PCB. You can get 10 for a few dollars now from various suppliers in China.
Bob
