AlbertHall
- Joined Jun 4, 2014
- 12,657
More gain = more transistors.
The thing about buying components from Amazon is that you're probably not buying from an authorized reseller. You could get lucky and find someone selling genuine parts and not knowing what they were actually worth, or you could be buying from a disreputable source that doesn't know or care where the parts came from or whether they're authentic.I bought these devices on Amazon. Does Mouser or Digikey have better prices than Amazon? Are there other companies you can suggest that have lower prices than Amazon?
Use oshpark, I despise China mfg.Thank you. Can you suggest any companies that do a good job of making pcb boards in China?
The datasheet for the LM386 shows that its simple gain is 20 times. It shows by adding a 10uF capacitor between pin 1 and pin 8 the gain is increased to 200 times.Possibly more gain from the amplifer. Other than that I am satisfied with the lm386 amplifier.
Prices are constantly in flux so you need to check several sources whenever you buy--I bought these devices on Amazon. Does Mouser or Digikey have better prices than Amazon? Are there other companies you can suggest that have lower prices than Amazon?
For price: AliExpress China, slow delivery (if at all, have lost several shipments)Thank you. Can you suggest any companies that do a good job of making pcb boards in China?
I love the simple transistor amplifier design by Rick Andersen. Low power but works.I am looking for a npn or pnp transistor substitute for the Lm 386 amplifier chip which powers a 8 ohm 1/2 watt speaker.
The reason that I want to make this switch is for cost, easier to solder to pref board, and less time to assemble and solder.
The lm386 is a good amplifer, however I want to reproduce the amplifier circuit using transistors, preferbly less that 2 transistors.
Try TDA7052. For a stereo audio amp IC, try TDA2822. The TDA2822, however, comes in a 16 pin package. Sorry.ok thanks
Just to cover my bases, What other 8 pin amplifiers are equivalent to the LM386.
I am interested in persuing other options if possible for experimental purposes.
I've found Digikey to be on the high side for most things. For that reason, I haven't bought anything from them for decades. They do have a large selection...Digikey or mouser would be my recommendation for cheap parts. You know your getting the real deal, and to be honest they're usually cheapest.
Have to sympathize with you on trying to avoid cheap parts that don't work right or at all. On the other hand, I do occasionally buy cheap parts in bulk on ebay from sellers in Asia. Sometimes the price is too good to pass up, especially if I want to buy 20, 50, or 100 pieces to keep in my "parts bin" for later use. When I buy in smaller quantities, I use choose a well-known USA-based vendor, such as Mouser, Digi-Key, Jameco, Newark, et cetera, because the cost is not that much greater than buying internationally and waiting weeks for parts to arrive.Since money grows on trees that I can reach and my government pays me to be retired then I do not save a few pennies buying good electronic parts. I also do not buy obsolete junk from "over there".
You can never have too many pot adjusters. I got a bunch from my Father-In-Law. He accumulated them while working as a technician. I collected a few when I was an R&D tech, but not that many. The Bourns ones on the right were from my existing stash:trim pot adjusters, the ones that have the blade on one end that is surrounded by a plastic ring to keep it from slipping off the pot? The kind that have a clips on them so you can wear them in your breast pocket? I can't seem to find those cheaply anywhere, not even on ebay. There are the genuine Bourns kind that you can get at Mouser for about $1.39 each.
It's not much more expensive, has free shipping (often makes up the difference in price), is always high quality enig finish. My only complaint is the boards are purple....
I will 2nd that. OSHpark is a reliable, fast and low cost maker of custom PC boards. There are several free or low cost design programs available on the web but the downside is it takes time to learn them.
I like the prices, but the 10USD shipping kills the deal for me. Unless it's a large order. Thanks for the heads up and I will bookmark it.Lately I found that TME.eu has much better prices
Ioannis
Try 2N2491, 2N441, ECG105, ELM105, 2N3315, 2N2081, HEP231I am looking for a npn or pnp transistor substitute for the Lm 386 amplifier chip which powers a 8 ohm 1/2 watt speaker.
