Transistor Substitute
AndyL5
Joined Jan 4, 2025
19
Hi I am hoping someone could help me with an old 1992 GM vehicle PC board. I have sketched out the circuit as best I can and attached photo of the original transistor. I cannot find any info on this transistor online. Looking for advice on a readily-available replacement item in the TO-92 type package. The relay that it switches has a coil resistance of 73ohms, so should need approx 0.2amps to operate it at 12vdc.
Any advice much appreciated.
AndyL5
Joined Jan 4, 2025
19
OK yes I see I can buy that one here locally.
Out of curiosity, does anyone have any old spec info on the original transistor.? I think it is a 3248 or N202.
Wondered if it had some high current capability or unusual characteristics...?
Thank you.
AndyL5
Joined Jan 4, 2025
19
I'm not sure since I could not find any reference to it on the 'net. I have to admit that the original part has worked since 1992, but then I see on a forum for the vehicle, that this particular failure is not uncommon... I was thinking a modern substitute may be more durable or even wondered if I could fit a device with a bit more capacity to avoid another failure.
dl324
Joined Mar 30, 2015
18,465
My first thought was that it could be a 2N3248, but that device is in TO-18.
As long as the substitute will handle at least 200mA, reliability shouldn't be an issue because the transistor is being used as a switch - either on or off.
If you go with BC337, be aware that the pinout is reversed from PN2222A and the device in question.
AndyL5
Joined Jan 4, 2025
19
Great thanks. I will see what my local store has available today. They claim that they have P2N2222A. I can rotate the transistor when I solder it on, to allow for reversed pinout if necessary I guess.
AndyL5
Joined Jan 4, 2025
19
OK this is where my very limited knowledge runs out. Maybe that original device did have some special characteristics.? Would that explain why it is difficult to find references to it? It shows in that photograph that I posted at the start of this thread..
sghioto
Joined Dec 31, 2017
8,751
There are two of those transistors next to each other. Maybe it's configured as a darlington.
If the TS can confirm the connections.
AndyL5
Joined Jan 4, 2025
19
No it’s just the one transistor. There are actually three identical circuits on the pcb which run three relays.
AndyL5
Joined Jan 4, 2025
19
No they are working fine still. I used those circuits to figure out how it works and to conclude that this one transistor is faulty.
