Is the Motor Damaged
Vihaan@123
Joined Oct 7, 2025
288
I wanted to use an old motor available and see if i can run it, when i was checking the back emf and the hall signals by hand rotation i observed the below waveforms, after looking at the waveforms i feel the motor is damaged is it correct? The motor details are as below, the hall waveforms are abnormal with short pulses in between.
Vihaan@123
Joined Oct 7, 2025
288
When i run the motor with hand and connected the phase to phase with differential probe I get the above waveform it is kind of trapezoidal waveform I have shown in the diagram.
Alec_t
Joined Sep 17, 2013
15,156
If you are rotating the motor by hand there will be jitter in the movement, which could result in the spurious spikes in the Hall signals.
MaxHeadRoom
Joined Jul 18, 2013
30,807
This is typically the waveforms obaserved when a motor is back-fed.
Used to align Commutation sensors.
BTW Hall sensors are a little passé now, usually optical is used for accuracy.
