It is grounded, I don't know if it has a calibrate output but I know it has a terminal that square wave and 1khz is written on itIs the ground lead grounded to the negative terminal?
Does the scope have a calibrate output?
Yeah thanks. I connected the probe to it I got got different frequency until I turned the knob I got 1khz. How would I know the magnitude if it is correct. Please enlighten me.That is the calibrate port. What happens when you connect your probe to it?
P | Taking measurements with an oscilloscope | Test & Measurement | 6 | |
E | Delay Hold circuit to turn on mini oscilloscope? | General Electronics Chat | 5 | |
Tektronix TDS 220 alternative Oscilloscope | Test & Measurement | 23 | ||
oscilloscope and load limit | Homework Help | 10 | ||
R | CRT oscilloscope not displaying | Technical Repair | 5 |
