Is it possible to wirelessly "connect" a circuit, for small voltages?
measuregreater
Joined Oct 2, 2018
7
Let me preface this by saying I am a complete novice when it comes to electronics. Hence why I am here. So please be nice, even if I'm talking absolute nonsense.
I have a simple query. Is there any way to wirelessly connect two ends of a circuit to give a readout on a multimeter?
I have attached a simple diagram of a multimeter connected to a 1.5v battery, showing what I mean.
Is there any way to bridge that gap to get a readout? Is it possible to do this with the following: Analogue to digital conversion - Wireless Transmission - digital to analogue conversion or possibly an easier way?
I'm looking for the simplest solution.
Thanks in advance,
S
WBahn
Joined Mar 31, 2012
33,185
Just to be sure I've got this straight -- you want to wireless connect a 1.5 V DC circuit across a 10,000 meter gap?
Let's take a step back. WHY do you want to do this? What problem is it that you are trying to solve?
measuregreater
Joined Oct 2, 2018
7
I'm involved in cathodic potential measurements on subsea pipelines. At present, when doing shallow water surveys we need to make a hard wire connection between a multimeter and the pipeline. One lead of a multimeter is connected to an passive electrode. The other is connected to the pipeline test point on the beach, through a small enamelled copper wire, running out the back of a boat, which is usually about 10km long. I am curious to know whether it's theoretically possible to do away with the wire and transmit the signal wirelessly.
Thanks,
S
WBahn
Joined Mar 31, 2012
33,185
Thanks,
S
I don't think so.
BobaMosfet
Joined Jul 1, 2009
2,211
If you are not transmitting through water, but just through air- this is what standard radio communications does. No need to reinvent the wheel. You just need an AM or FM signal at a given base frequency for your carrier that you can transmit and receive on at a high-enough wattage to make the distance.
ericgibbs
Joined Jan 29, 2010
21,568
hi,
The problem is that you are using the enamelled copper wire as part of a circuit for measuring a low analog voltage, its a closed 'current' loop.
Break that loop and you have no current path.
E
measuregreater
Joined Oct 2, 2018
7
hi,
E
Your diagram is correct except that the connection on the beach is physically connected to the pipe, not a cathode.
Yes, I'm starting to realise that once you break the physical connection, there is no current flow and there would be no way to simulate that.
ebp
Joined Feb 8, 2018
2,332
When you say "survey" - are you working your way along the path of the pipeline, making measurements from near shore to 10 km out? I'm assuming from the voltage mentioned the protection current is off during the survey. Copper-copper sulfate half-cell electrode?
