Electrocution - What can be the possible reason?
lichurbagan
Joined Jul 4, 2025
139
In a recent accident in my country, a mother and her child whom she was holding in her arms died from electrocution as soon as the mother turned on a rice cooker. I was shocked and afraid after hearing this. What can be the possible reason behind such an accident?
I do not expect that there will be any investigation on whether it was a faulty cooker or a serious fault in the electric line of the house. But I really want to know what can bring such mishaps?
I never use any electrical appliance that has worn out wires. I avoid using low quality extension cables too. What else can I do to assure that nothing like this happens to me?
boostbuck
Joined Oct 5, 2017
1,067
Normally result from a faulty earth protection, either at the device or in the electrical supply in the household. If you are concerned about such dangers caused by faults or poor installation practice, simple testers are easy to come by.
28,576
The reason for the electrocution was a connection from the mains "hot side" to A PART OF THE RICE COOKER THAT THE WOMAN WAS TOUCHING, AND she was also touching something connected to the neutral side of the mains. THAT connection could have been barefoot on a cement floor, or it could have been a metal sink, or a metal faucet. It could even have been a "properly grounded" appliance, such as a toaster or a mixer or an electric water heating kettle.
As for a safety rule to avoid such injuries, ALWAYS avoid touching anything else, such as a faucet or any other appliance, when touching an electrical appliance. It does take two connections to get a shock. That could be your feet or your other hand, or a metal chair you are sitting on.
Another option is to install GROUND FAULT INTERRUPTER outlets, because they will switch off the power before any shock is able do do any harm.
Ian0
Joined Aug 7, 2020
13,315
Was the rice cooker Class II (with a two core cable) or was it Class I (with a 3 core cable)?
If it was Class II, then the incident was caused, without doubt, by a fault on the appliance itself.
If it was Class I, then it is still most likely that it was caused by a fault on the appliance itself, or it could be caused by a fault in the earth wiring to the socket into which it was plugged, but, if that were the case, then other appliances plugged into the same socket would be live if any metal parts on them were touched.
lichurbagan
Joined Jul 4, 2025
139
Sir, could you please let me know how to identify class 1 and class II? I mean, to know if the cooker comes with a 2-core cable or a 3-code cable, we need to cut the cable, remove the insulation and check, right? Is there any way to know from outside before making a purchase? Thanks.
lichurbagan
Joined Jul 4, 2025
139
Sir, how can I look for and identify GROUND FAULT INTERRUPTER outlets? Is there any particular company that manufactures these outlets? Thank you.
Ian0
Joined Aug 7, 2020
13,315
Firstly, depending on what country you are in (you didn't say) does it have a 2-pin or 3-pin plug? If your country doesn't have 2-pin plugs, look at the shape of the cable. If it is flat it is definitely two-core.
wayneh
Joined Sep 9, 2010
18,184
There's also a possibility that the "journalist" buggered the facts so badly that the story barely resembles reality. If you've ever been involved in a newsworthy event, you'll know what I mean. The stories in the press made me wonder if it was the same event I was a witness to. Maybe it was pressurized and blew up. Who knows?
Hymie
Joined Mar 30, 2018
1,347
I believe this is the news story the OP is referring to:-
https://www.observerbd.com/news/531180
One reliable way of avoiding this type of incident in the home is to have the house electrics protected by a Ground Fault Interrupter (or Earth Leakage device), that detects a current imbalance between the supply Live and return Neutral – cutting the supply when such is detected.
Sad story, completely preventable by simple measures and education.
