is a TIP42G transistor compatible with a 2n6667
dfullersnap
Joined Jun 19, 2011
9
Is a TIP42G pnp transistor from radio shack a close enough match with a 2n6667 Darlington PNP to use the TIP42G instead.
Thanks
bertus
Joined Apr 5, 2008
23,026
Without the schematic we can not tell if you can use it.
The posibity to use it depends on the application.
ifixit
Joined Nov 20, 2008
652
Hi dfullersnap,
The MJD44E2 in the schematic is a darlington transistor, 80V, 10A, 20W, which a good match with the 2N6667, but not the TIP42, which is a 6A, non-darlington device. The much higher Hfe (gain) of the darlington device might needed by the circuit.
Does radio shack have any darlington PNP transistors, 80V, 10A, 20W?
BTW, the schematic appears to be confidential to Hobart. In the future, post only a snippet of the schematic so that it is useful for the purpose, but not identifiable for any peticular product, or application that is proprietary in nature.
Regards,
Ifixit
THE_RB
Joined Feb 11, 2008
5,438
According to my cross-reference book;
2N6667 = Si-P-Darl+di 60v 8A 65W B>1000
be careful you need a part with an internal diode;
listed replacements are; BD646 BD898 BDW74A BDX54A
