I mean measure it while it's operating.what do u mean by measuring? 15 vdc is the optimum voltage that is measured many times before applying it as Vdc
yes, i have measure its being operated the voltage remains constantI mean measure it while it's operating.
I don´t see anything called D1 in the schematic from post #15. Did you change it?D1 is 1n4048, VGS IS 2-3Volts.
vs-com is not measured.
any further advices
i think he is referring to the original schematicI don´t see anything called D1 in the schematic from post #15. Did you change it?
yes it is very less according to the datasheet to provide enough current, that is the reason i cannot find out what could be the problem...i have never driven the mosfet with a driver like ir2110 always used a resistive network wich always worked,,,but now for buck converter controlling i require it.Not sure if I understand the circuit, but isn't a Vgs of 2-3V asking for trouble? The threshold for that MOSFET is anywhere from 2-4V so you might be making it sweat.
That value sounds way to high. That's likely nF not uF. I think you need to redo your calculations.................
Making an assumption or two about your circuit I got a value of 42uF which multiplied by 15 gives 630uF. Perhaps this is why your IC is getting hot.
any further advices
