Inverting v Non-Inverting Amplifiers
b0mbst3r
Joined Oct 13, 2016
5
Above is an example of an Operational Amplifier.
Anyone able to explain how better gains are achieved from Inverting Amplifiers than from Non-Inverting Amplifiers, could someone please shed some light on this please, thank you in advance.
For any gain I can design into an inverting op-amp circuit, I can design that into a non-inverting op-amp circuit.
This holds true until you get to the frequency or slew rate limit of the chip, at which point, I don't know which one wins.
So, for most practical purposes, your question is false.
If you're going to arrive at a difference in capabilities, you're going to have to narrow down the question to some conditions or requirements besides merely "inverting vs non-inverting".
38,533
One difference in gain is that an inverting amp can have a gain of less than 1 whereas the minimum gain of a non-inverting amp is 1.
But both configurations can achieve essentially the same gain as determined by the feedback resistors.
The other difference is in the bandwidth.
The bandwidth of a non-inverting amp is the GBW of the op amp divided by the circuit gain (GBW is the gain-bandwidth product of the op amp).
The bandwidth of an inverting amp is the GBW divided by the (gain+1).
#12
Wally thought of the "less than one" gain which I completely disregarded and provided the math showing that the non-inverting configuration has a small advantage in the frequency limit end of the application.
I don't think so.
38,533
Actually the biggest bandwidth advantage occurs for low gains where, for example, the bandwidth for a gain of +1 is twice the bandwidth for a gain of -1.
38,533
Anyone able to explain how better gains are achieved from Inverting Amplifiers than from Non-Inverting Amplifiers, .........
If you are referring to the difference in gain that MrChips showed above, it's basically that the non-inverting amplifier has the input signal added to the amplifier gain of Rf/Rin thus giving a total gain of 1+Rf/Rin.
(And that's why the gain of a non-inverting amp can never be less than 1.)
hp1729
Joined Nov 23, 2015
2,304
What did you read that suggested there is a difference?
