Inverting Amplifier
manictadpole
Joined Mar 10, 2021
I am stuck on the following questions with regard to an inverting amplifier. I cant seem to get my head around the questions? Can anyone help pointing me in the right direction to calculate the values required. The gain for the circuit is -100. Thanks.
  • Calculate gain in dB; (20log(gain) = gain in dB) dB Gain =
  • Calculate the gain at cut-off frequency; fc = dB Gain -3dB =
  • Calculate arithmetic gain (A) at fc; A = 10^fc dB/20 =
  • Multiply Vin peak-to-peak voltage by A; Vout at fc =
manictadpole
Joined Mar 10, 2021
Hi, I have below the attempts to solve the posted problems.
Gain = 40
Gain at Cut off = 40-3=37
Gain (A) = 10^37/20 = 5x10^35
Vout at fc = 30x(5x10^35) = 1.5x10^37
Audioguru again
Joined Oct 21, 2019
6,826
The gain is said to be -100 but you say it is 40. Don't you mean to say the gain is 40dB?
You say the gain at cutoff is 37 but instead it is 37dB.
37dB is 3dB less than a gain of 100 times then the answer is 70.7 times.
Vout at fc is unknown since we do not know Vin the input level or input frequency.
