KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
the easiest voltage to start out with is filtered half wave 240 or full wave rectified 120 which is the same voltage.
Yes, you can reduce the input voltage and achieve a lower power output. This is very hard on the magnetron as it also reduces the heating to the filament. It also lowers the high voltage pulse amplitude and the efficiency. Other techniques work better, for example; at Litton we shortened the cycle time when someone entered short cooking times. If you entered a short time, say 50 seconds then at 50% then the cycle time was 10 seconds, 5 off and 5 on. In actual practice it was closer to 6 on 4 off due to the fact that it took more than a second to heat the filament. At longer cooking times the cycle was 30 seconds total.Hello there,
You dont understand probably because you did not read this whole thread before you replied.
First, no one is trying to vary the input power to an already inverter type microwave oven. The input power vary method was being used for NON inverter ovens only. That turns a pulsing on/off type controlled oven into a smooth variable power controlled oven. So we start out with a regular non inverter oven and set it on HIGH, then use the Variac on the input to change the power level in a continuous manner rather than a slow pulse manner.
We know there are inverter type ovens, but they are more expensive than the cheap run of the mill non inverter ovens. So if you have a variac you can use it on a regular oven and get smooth power level settings.
If you worked in this industry then maybe you can tell us more.
Hi,Yes, you can reduce the input voltage and achieve a lower power output. This is very hard on the magnetron as it also reduces the heating to the filament. It also lowers the high voltage pulse amplitude and the efficiency. Other techniques work better, for example; at Litton we shortened the cycle time when someone entered short cooking times. If you entered a short time, say 50 seconds then at 50% then the cycle time was 10 seconds, 5 off and 5 on. In actual practice it was closer to 6 on 4 off due to the fact that it took more than a second to heat the filament. At longer cooking times the cycle was 30 seconds total.
One of the factors that most people don't recognize about microwave ovens is the penetration depth of the microwave energy into the food. This has a substantial impact on uniformity of cooking. Microwaves will penetrate to about 2.5 cm, give or take depending on the food. If the food is substantially non-uniform the thinner parts will heat first. Even if the food is uniform the edges will heat more since the energy enters from three directions. Lowering the power achieves more uniformity because it gives the energy more time to spread.
Inverter technology doesn't change these factors much since it is mostly about the magnetron. Inverters allow more power at a lower cost. There are ways to increase the power with the older style reactor voltage doubler but it would require two sets of reactors, capacitors and diodes. More weight and much higher cost. Higher power means the energy doesn't have as much time to spread and the cooking uniformity can actually decrease. However, since the frequency is so much higher, the cycle time for power control is much shorter.
Power output was always one of the principal selling features of the oven. Inverters provide a lot more power therefore higher sales. It is all about marketing.
When talking about industrial not home appliance "inverter technology" most times it means they are using a form of switch mode technology. Stuff like welders are smaller because of doing it switch mode, as do VFDs to a certain point.
Charlie: Of the several ovens I've torn apart, and of the magnetrons I've cut open I've never found a filament in any of them. It was my understanding that the magnetron chamber directed and redirected energy in a circular sort of fashion to achieve the "Micro" waves. There was some sort of resonance set up. I've never found any micro wave chips in any of the ovens I've opened. I'm talking about the driver for a microwave transmitter used in communications.This is very hard on the magnetron as it also reduces the heating to the filament.
the ceramic looking insulator at the top & bottom if damaged by cutting or grinding is poisonous.
I'm fairly certain it is primarily copper but it could be an alloy. There is no technical reason to make it from beryllium.Yes, I know it's beryllium.
As for the heater, I guess I've never seen it because perhaps it's within the beryllium body. Which I've never cut into, broke or crushed. I know about the hazards of beryllium.
The term of art 'Inverter' function simply provides an impedance match (acts like a fixed optimized transformer at all power levels) for efficient power transfer at different power levels from a power source voltage/current ratio to another load voltage/current ratio. In mechanical terms it's a variable gear ratio (transmission).The only thing I know about inverters is that they convert DC into AC.
beryllium?
Wish the places I worked at did. Did a lot of grinding of beryllium copper at one place and EDMing(vaporizing it) at another, before they found out about the hazard.I know about the hazards of beryllium
