Inverter Circuit feeded by Solar Panel
Alkim Gokcen
Joined Mar 29, 2017
22
Hello everyone
My professor wanted me to design a Inverter circuit wich is going to be get the input DC voltage from a Solar Panel and this input will be inverted AC Signal.And the frequence of this signal will be equal to the frequence of the PWM signal wich is supplied to Inverter Circuit again.
Can i get your suggestions to create a algorithm to design this circuit.
Thank you,everyone.
Papabravo
Joined Feb 24, 2006
22,111
Are you at all familiar with any of the circuitry that you might use in such a design? Do you have any specifications that will define what DONE means?
Look for TI Application Report SLAA602 - June 2013 for more information.
Alkim Gokcen
Joined Mar 29, 2017
22
have not any kind of specifications about the circuit,all the things i now about circuit is written above,thank you.
new edit:
SLAA602 is all i need,i think. thanks you so much
Papabravo
Joined Feb 24, 2006
22,111
Then you are truly at sea! I guess your first task is to develop a set of specifications that defines what done means. That is where all successful design projects begin. You will make absolutely no progress if you cannot put the horse before the cart.
BTW -- IMHO this would be a reasonable project for a graduate level electrical engineer with at least four semesters of circuit design and couple in microcontroller programming.
Papabravo
Joined Feb 24, 2006
22,111
new edit:
I think you will have more questions, particularly on how microcontrollers measure things and generate a PWM signal.
