Yes, a 1:1 isolation transformer will get you approximately 170 DC minus 1.4 volts for rectification and such. Short of using a Variac or winding a custom transformer that seems like the easiest path. You still need to allow for a center tapped secondary so you can get both rails.I assume you mean the standard one puts out 120VAC, which yields roughly 170VDC only after rectification and ripple filtering.
