I have simmed it in LT spice. also 9V is seems OK. You expect a problem with 9V in "real life" ?Actually the supply should probably be as least 12V
The op amp input is a resistor so you don't need the added 1 Meg resistor since the two are effectively in parallel...................
in the article ref.d in #1 on page 5 they explain the R as "
A second capacitor of about l000pF should be connected as shown. The capacitive divider thus formed divides the input signal by about 1000:1 thus reducing the input signal to a workable 3 - 20 volts. A 1M resistor should be connected across the 1000pF capacitor to provide a dc load. "
9V will give you a positive peak voltage of about 3.5V before it starts to clip, if that's okay.I have simmed it in LT spice. also 9V is seems OK. You expect a problem with 9V in "real life" ?
Thanks, I 'll take some more samples with the bitscope to check the wave form later on this week. I read that in worst case scen. it can go to 50KV. So input protection becomes very important. You have an idea on the right TVS's or other protection methods? Even for a direct spark pick up?The op amp input is a resistor so you don't need the added 1 Meg resistor since the two are effectively in parallel.
So remove the external 1 Meg resistor and change the op amp input resistor to 1 Meg.
Then a feed back resistor of 100k will give you a gain of 0.1.
Since the positive peak voltage is greater than the negative peak, you can add some additional headroom to the positive peak output voltage by reducing the DC voltage to the (+) op amp input (reducing the value of Rb in the Figure 3 schematic).
You can adjust Rb until the negative voltage peak is near zero at the op amp output.
You're right about the clipping. I can go up to 50V which I did. Output stil very small for my bitscope... and not inversed. Why???You didn't post you PWL file so I don't know the characteristics of the pulse.
For a gain of 0.1, R5 should be 1 meg and R6 should be 100k as I previously suggested.
Why are you clipping the signal at 12V, when it has a peak value of 50V at that point?
I see U have a good inversion. But.... I have done the same sim with the LM324. Results are not equal. As U can see in my signals as below, not all waves are inverted especially the first and the last are not, while in yr sim all are inverted and the segment after the lage peak should slowly rise since it is falling at the input..... Further on I see a negative peak just before the large peak on the output, where this (inverted) is not present on the input) Exactly those details are important in the interpretation of the waveform from ignitions. What is the diff between our diagrams, I wouldnt know... different spice model or diffrenece in the .TRAN?Here's my simulation, which seems to work fine, so I don't know what the problem is with yours. The output is a pulse of about +4.5V.
I changed R1 to 20k to give more positive output voltage headroom for the op amp.
I used an LM324 op amp, which is basically a quad version of the LM358, since I don't have the LM358 model.
Why did you reduce the value of the decoupling capacitor C5?
Many thanks for all yr help!! Guess it was to late at night for me...You have the inputs reversed on the op amp. Take a closer look at my diagram.
Your connection give positive feedback instead of the negative feedback you want.
Yes, the time-constant of the 1000pF cap and the 1 meg input resistor is only 1 ms which is too short to see the slow rise in signal, since that time is also about 1 ms.Many thanks for all yr help!! Guess it was to late at night for me...
I only see one thing I do not like 100% and it is the segment after the large peak which should be rising since the input is falling. Do you see a solution for it?
Fantastic!! Thanks to yr explanation I have also the opportunity to learn about opamps!Yes, the time-constant of the 1000pF cap and the 1 meg input resistor is only 1 ms which is too short to see the slow rise in signal, since that time is also about 1 ms.
Change R5 to 10 Meg and R6 to 1 meg, which increases the time-constant to 10 ms.
See results below.
Now the slow slope changes are reproduced accurately at the inverted op amp output.
I 'll keep U informed after a few tests !!To minimize battery noise and spikes I would put a 10Ω resistor in series with the battery connection and use at least 100μF to ground at the op amp power pin along with a 0.1μF ceramic cap in parallel.
Place the neon and zeners close to the circuit with short connections between the signal and ground
If you use both tubes, that will approximately double the pickup capacitance and thus double the voltage.
Obviously the length of the tube also affects the capacitance.
A shield ground connection directly to the engine block and to the circuit ground may give you a better signal.
You can try it both ways and see.
