Interlocking between manual switches
sab201
Joined Nov 18, 2023
297
What are the loads?
Still not seeing the complete circuit.
The load of the Radio PB Circuit is the PWM circuits 1 to 7 which give PWM output to the MOSFET switching module shown above. This MOSFET module switches power ON and OFF to another main load which is a DC electromagnet that is shown in the circuit. The load of the Radio PB circuit is only the PWM s and the MOSFET module.
ElectricSpidey
Joined Dec 2, 2017
3,334
Instead of powering the 555s with the outputs of the radio button circuit, connect the outputs to the reset line of the 555s instead.
That way when any radio button output is high the analog switch will be closed and that 555 will be active.
sab201
Joined Nov 18, 2023
297
Ok, so I power all the 555 timers from the power source all the time, and when the reset pin is connected to the radio PB output that 555 timer will be active giving the PWM output to the 4016. Now I have to change the reset connections of all the PWM circuits. I will try that. Thanks.
sab201
Joined Nov 18, 2023
297
Can't the Radio PB output be directly connected to the reset pins of the 555s? It does not need to go through the 4016 to the reset pin. 4016 is only to make sure the other 555 timers are isolated when one is giving PWM output it is not present at the output pins of the rest of the 555s. That is the purpose of 4016.
Each output of the Radio PB circuit goes to corresponding 4016 control pin and to the reset of the 555. I made changes to the circuit here
eetech00
Joined Jun 8, 2013
4,705
This is the circuit in post #67 without the 4016 ICs.
View attachment 327794This is the MOSFET switching module.
View attachment 327795The PWM signal is given to this module which switches the 12 Volts supply ON and OFF to the load at different frequencies of the PWM. I suppose the load of the PWM circuits is only this MOSFET module and it draws small current only to switch ON and OFF like a relay or contactor.
I updated my circuit to show the Mosfet Module. See Below.
BTW - You can run the whole circuit with 12v DC supply if you wish.
sab201
Joined Nov 18, 2023
297
Those are unused pins and do not connect to anything.
Ok so I may not have understood its working clearly but as per the circuit I am thinking that all the PWM circuits are ON all the time powered from a different source generating PWM outputs and when the push button is pressed, the selected output is sent to the MOSFET module.
eetech00
Joined Jun 8, 2013
4,705
Yes, and as Crutchow mentioned, they should all use the same supply voltage as the rest of the circuit. Your using NE555's, that's OK , but I would use the CMOS LMC555's instead because they use much less power and they don't need to provide much drive output.
ElectricSpidey
Joined Dec 2, 2017
3,334
I don't think the OP wants all of the 555s to be active at the same time because they want to have LED indicators on the outputs to show which one is providing the output.
eetech00
Joined Jun 8, 2013
4,705
No problem.
I added another CD4051B (U3) to activate the selected 555 generator. Each 555 reset is normally pulled down unless selected.
The TS can add an LED to each output to show the active generator. If we want, we can get fancy and use a single 7-segment display and 7-segment Driver (CD4511B) to show the selected output.
sab201
Joined Nov 18, 2023
297
No problem.
As ElectricSpidey said I like to have indicating lights and each one pwm active at time. Thanks for the modified circuit. :)
