Instability of DC-DC Converter
Ravi Teja 2
Joined Dec 5, 2016
23
I am using a DC-DC converter(Schematic below) which converts +15V to -15V which is used to drive a 6W DC motor.
-15V_IN rail is connected to the motor. Whenever the motor is drawing the power from the converter i see a disturbance as shown in the image below(Blue trace is -15V_IN)
and when the motor is trying to drive against the gravity i see a dip in the voltage as shown in the image below.(Blue trace is -15V_IN)
Can anyone help me understand the problem and suggest a solution to it?
38,790
Is the yellow trace, the input voltage?
It would appear the motor current is too high for the converter.
What is the motor voltage rating?
Have you measured the motor current?
Ravi Teja 2
Joined Dec 5, 2016
23
Is the yellow trace, the input voltage?--> No, Its some other signal on the system
What is the motor voltage rating? 12V/6W Stall Current is around 2.17A
Have you measured the motor current? No
BobaMosfet
Joined Jul 1, 2009
2,211
You have to design DC DC converters to output the necessary current at the necessary voltage. Anytime you see voltage sag when a current device is drawing current, it means too much current is being drawn. Ohm's Law.
bertus
Joined Apr 5, 2008
23,005
As said, the converter might sag as it can deliver 1.5 A max.
The given stall current of 2.17 A is to much for the converter.
Bertus
