Input capacitor gets very hot
Ian0
Joined Aug 7, 2020
13,202
22Ω is a bit high. A good first choice is the same value as the load, about 1Ω.
The drain waveform should be a squarewave, amplitude 24V, if the transformer is correct.
Janis59
Joined Aug 21, 2017
1,893
1) You should check the ESR factor of this cap. Thermal flux in Watts is i^2*ESR.
2) You should parallel it with few 0.1 mkF fast caps to avoid the rapid pulses overstressing it by the di/dt
myil
Joined May 2, 2020
148
Can I also add a choke to avoid back emf to battery?
Ian0
Joined Aug 7, 2020
13,202
I don’t think it will help. The battery will get rid of the back emf!
the problem is elsewhere. Is the off-load transformer waveform clean?
DickCappels
Joined Aug 21, 2008
10,661
You had the wrong capacitor but that capacitor is gone now. I hope you have an idea of the ripple current so you can select a good replacement.
Lyes
Joined Nov 25, 2019
12
I have applied a snubber network across the mosfets according the steps in the link down below. It reduced the ringing a lot but the amplitude of the peaks still remain the same. Have any idea how to reduce the amplitude as well?
https://e2e.ti.com/blogs_/b/powerhouse/archive/2016/05/05/calculate-an-r-c-snubber-in-seven-steps
overvoltages are due to a parasitic inductance in the transformer, so it is normal to have these spikes however you must not add more with the layout
to cope you need to oversize the mosfet voltage VDss, (for 24V input a 80V mosfets should be ok)
you can increase the gate resistances but you will have more losses (heat)
using a snuber through the primary mosfets is difficult because the current is high,
the solution is perhaps to put it @ the second.
