Input capacitor gets very hot
myil
Joined May 2, 2020
148
Did you check the polarity of the capacitor on the board?
Yes, I did. Without a load, it operates under room temperature as it should. Once the output current increases, it starts to get hot. When I last checked it, the output voltage was 150V , I decreased the output voltage to 150V for a load test, and the output current was 0.7A. The capacitor was about to burn.
38,879
Those pictures look like you have ≈8A of ripple current through the capacitor, and it's likely higher than that without the resistor, so that's probably the cause of the heating.
To minimize the heating you could use several smaller capacitors in parallel so they share the ripple current.
Remember that capacitor has to supply the peak current of the transformer primary, which is at least ten times the secondary current.
Ian0
Joined Aug 7, 2020
13,298
I'd suggest a film capacitor of several microfarads to deal with the high frequency stuff in parallel with the electrolytic. Electrolytics get quite inductive at high frequencies.
Is it possible to observe the back EMF on oscilloscope? If so, how can I do that?
It's the voltage on the drain of the MOSFET.
Totally right. As a student, I could only afford a cheap one.
Spend more on the capacitor and less on the opto-isolator! A PC817 will do!
jtn
Joined Mar 27, 2017
22
It is better to redesign the input filter stage to an LC filter network. With LC filter configuration, you could reduce the input capacitance. If possible, use multi layer ceramic capacitor which has low ESR
Ian0
Joined Aug 7, 2020
13,298
I'm not sure a series L will help. Firstly, the battery's ESR was originally in parallel with the capacitor ESR which reduced the hf ripple current into and out of the capacitor. Secondly, with reduced parallel capacitance, and increased series impedance the voltage ripple on the 12V rail will be increased, not reduced.
I'd bet that the high ripple current was caused by transformer saturation, due to the uneven waveform; and that if the circuit were working properly, there would be no problem with the original capacitor.
Ian0
Joined Aug 7, 2020
13,298
Sorry, I'm lost. Where is the 20k resistor? Is it all still supplied from the battery? Where does the load tester go?
myil
Joined May 2, 2020
148
Yes, it's supplied from battery. I used load tester first but recently I switched over to 20k resistor to see if there is any difference between the load tester and normal resistor.
bertus
Joined Apr 5, 2008
23,014
Was the polarity of the capacitor the right way?
Having the capacitor in reverse polarity will heat up the capacitor with the possibility of blowing up the capacitor.
Bertus
Ian0
Joined Aug 7, 2020
13,298
Hope it didn't smell too bad. (My colleague put a 63V capacitor on 108V last week, and after it expired there was a foul smell in the lab for the rest of the day, still noticeable the following morning)
Does it work without the capacitor? Shouldn't be a problem on a battery with short leads.
myil
Joined May 2, 2020
148
Bertus
Polarity was correct, but having a heating problem, probably due to ripple current :S
myil
Joined May 2, 2020
148
I knew it would happen. I have been wearing my workshop glasses in case of blowing up. But couldn't protect my face from the hot liquid. It's kind of greasy and smells bad as you said. Btw, I didn't try without a cap, replaced it with a new one :D
