I have an interest to learn more about inductors and their saturation point. So I created an Inductor saturator test circuit based on http://www.vk2zay.net/article/200.
The diode was removed across the inductor on the breadboard because compared to vk2zay circuit. With it in place I couldnt generate any change in voltage slope across the shunt R1.
Below are the results. Not seeing a knee up change of slope that indicates saturation but a drop-off instead. Does this drop also provide a saturation indication?
Turns 33
Color Black
V volts 15
kHz 20
t delta t us 3.16
v delta V 0.318
R Resistance 0.47
I Amps I 0.676596
L Inductance 70
Next, I tested an inductor marked 560uH. However, after taking the readings and running the numbers the inductance comes out at 841uH. Did I make an error in the calculation or the readings flawed?
Purchased Inductor 560 uH
V volts 15
kHz 20
t delta t us 23.5
v delta V 0.197
R Resistance 0.47
I Amps I 0.419149
L Inductance 841
L=V/I*t
Im a learning hobbyist, and appreciate any comments.
Thanks,
Boondocker
Turns 33
Color Black
V volts 15
kHz 20
t delta t us 3.16
v delta V 0.318
R Resistance 0.47
I Amps I 0.676596
L Inductance 70
V volts 15
kHz 20
t delta t us 23.5
v delta V 0.197
R Resistance 0.47
I Amps I 0.419149
L Inductance 841
L=V/I*t
Thanks,
Boondocker
