Inductor block AC and pass DC
robo29
Joined Nov 24, 2016
66
I made inductor of thin(good) coper coil on iron drill bit but the inductor does not stop the AC going in the transformer of 12V 1Amp why?
AlbertHall
Joined Jun 4, 2014
12,663
Inductors do not 'block' AC. An inductor has a higher impedance to AC than it does to DC so it will reduce the AC current but it will not reduce it to zero.
robo29
Joined Nov 24, 2016
66
Capacitor block DC And pass AC i have done practically.
But Inductor block AC i have studied in class.
ok, how to know the current will be reduced?
at what value??
AlbertHall
Joined Jun 4, 2014
12,663
Real capacitors are much nearer to being 'ideal' than are real inductors.
The impedance of an inductor is 2*PI*F*L where F is the frequency of the AC and L is the inductance.
How much that impedance reduces the AC current depends on the impedance of the source and load circuits
Kermit2
Joined Feb 5, 2010
4,159
A transformer is two copper wire coils wrapped around a ferrous core.
You made an inductor out of copper wire wrapped around a ferrous core.
Why did you think it would block AC if the transformer didn't block it?
38,952
Capacitors block DC and generate an impedance to AC proportional to the capacitor value and inversely proportional to the frequency.
Inductors pass DC and generate an impedance to AC proportional to both the inductor value and the frequency.
Inductors do not "block" AC.
