Induction motor expirment
IbrahimF
Joined Jul 21, 2017
25
Hello
I am currently doing an experiment for an 3 phase induction motor with a power rating of 250 W.
I have calculated the predicted current vs speed and plot it against the practical.
also here is a torque against speed graph with predicted and practical measurements at 30 Hz
Can someone please explain the differences between predicted and practical measurements and why they happen.
wayneh
Joined Sep 9, 2010
18,104
The answer seems obvious. The model you used to make your predictions, which is a mystery to us because you haven't shared it, is not a good model. Or, your data is poor. Or both.
IbrahimF
Joined Jul 21, 2017
25
Also how can I estimate friction and windage torque from the given values
Rs=33.8
Rr=29.5
Xs= 26.8
Xr=26.8
Xm=702
Pf= 16.5
IbrahimF
Joined Jul 21, 2017
25
alright, it seemed I figured it out. can someone please explain the relationship between current and speed in an induction motor.
also how can I calculate the friction and windage loss in an induction motor.
MaxHeadRoom
Joined Jul 18, 2013
30,662
An induction motor attempts to run at synchronism, and RPM is dependent on slip and number of poles.
Increase in current usually accompanied by increase in slip frequency.
Slip= synchronous speed - actual rpm.
Max.
