in Quartus how can i calculate 2(4bit) number addition process
ValarVictorius
Joined Nov 17, 2015
19
How can i addition 2 (4 bit) number in altera quartus program with only one mux(multiplexor) and write the result to led's or 7segment screen ?
22,084
In Quartus you have two methods of design input. HDL (Hardware Description Language) or schematic entry. When you use schematic entry you usually have access to a library of modules. One of the modules in a library is likely to be a multiplexer of some description. I need to know what kind of multiplexers you have available. What's so hard about that?
ValarVictorius
Joined Nov 17, 2015
19
I watched tutorial videos, write some hdl codes. But i don't run my code anywhere.
Debasedly Ex:
module part1(SW,LEDR);
input[9:0] SW;
output [9:0] LEDR;
assign LEDR=SW;
endmodule
How can i see how my code working ?
22,084
It looks like you are trying to write VHDL. To see your code working you need a functional simulator, or you need to do the syntheses step and load the code into an actual device.
