Maybe you should read what you post!Again do read what you post? When a motor especially a DC motor starts to stall, it demands more current not less. You continue to mislead people.
My guess is that if a single op-amp can produce something like a saw-tooth /triangle wave, the second op-amp may act as a comparator to give a voltage controlled PWM. The transistor, as mentioned, just amplifies that to power the motor.
True, but if you are making several million for export, every 1% is $10,000 x "several" to take home. Hence the use of old chips with no discernible difference in performance.There are dedicated chips to produce PWM..
Which can save the designer of the circuit to implement it, using components like this..
Like I said go back and read the link you posted. An electric motor draws its highest current when under load, when it is getting full voltage and something(load) is slowing it down. And at it's start it is not turning is just like when it is under load. You do understand that a motor under load is a motor not turning its proper RPM don't you?Maybe you should read what you post!
https://physics.stackexchange.com/q...rs-draw-current-even-when-they-are-not-moving
In my opinion, you can do without a stabilizer when powering the drill from a voltage not exceeding 20 volts. The nominal potentiometer can be increased.
Don't keep trying to convince me of something that YOU believe that is just not true. Spend the time trying to understand and learn.What don't you understand !? Because it demands more current, we have a regulation to reduce it!
Explain?Fake news-DT
